Нужна помощь диагностов по ошибкам
Автор orackul, 25 января 2013, 16:06
orackul
Запустил форскан он выдал ошибки, а что по сути с ними делать не знаю
Interface:
Connection status: connected
Port: COM9, 38400 bps
Adapter: ELM327 v1.2a
Vehicle:
Found module: Powertrain Control Module (PCM)
Bus: Ford SCP
Strategy file: PCAG6H5.HEX, Copyright Ford Motor Co. 1999
Part number: YL2FCA
Found module: Anti-Lock Brake System (ABS)
Bus: Ford ISO
Part number: XL2T-AC
Found module: Generic Electronic Module (GEM)
Bus: Ford ISO
Part number: XL2T-14B205-CD
Found module: Restraint Control Module (RCM)
Bus: Ford ISO
Part number: XL2A-AD
Found module: Driver Seat Module (DSM)
Bus: Ford ISO
Part number: YL24-AA
Code: P1804
Module: GEM
Explanation: 4-Wheel Drive High Indicator Circuit Failure
Code: B1453
Module: GEM
Explanation: Wiper Wash/Delay Switch Circuit Short To Ground
Code: B1869
Module: RCM
Explanation: Lamp Air Bag Warning Indicator Circuit Open
Code: B1998
Module: RCM
Explanation: Passenger Side, Side mount Airbag Circuit Open
Code: B1676
Module: DSM
Explanation: Battery Pack Voltage Out Of Range
Code: B1342
Module: DSM
Explanation: GEM Defective
Code: P1703
Module: PCM
Explanation: Brake Switch Out Of Self Test Range
Alternative Explanation: Brake Switch Out of Self-Test Range
Detailed Explanation: Indicates that during Key On Engine Off (KOEO) Self-Test, BPP signal was high. Or during Key On Engine Running (KOER) Self -Test, the BPP signal did not cycle high and low.
Possible Causes:
- Open or short in (BPP) circuit
- Open or short in stoplamp circuits
- Damaged PCM
- Malfunction in module(s) connected to BPP circuit (Rear Electronic Module [REM] Windstar, LS6/LS8 and Thunderbird or Lighting Control Module (LCM) for Town Car)
- Damaged Brake Switch
- Misadjusted Brake Switch
Diagnostic Aides: Check for proper function of stoplamps. Using scan tool, check BPP PID. Stoplamps and PID should toggle on and off with brake pedal activation.
Code: P1780
Module: PCM
Explanation: Transmission Control Switch (O/D Cancel) Circuit Out Of Self Test Range
Alternative Explanation: Transmission Control Switch Out of Self-Test Range
Detailed Explanation: During KOER self-test the TCS has to be cycled, if not cycled a DTC is set.
Possible Causes:
- TCS circuit short or open
- Damaged TCS switch
- Damaged PCM
Diagnostic Aides: Verify the TCS switch cycles ON/OFF
скопировал все что выдал форскан
Спасибо!
altmirage
Цитата: orackul от 25 января 2013, 16:06C1233
C1233
B1894
B1869
B1998
B1676
B1342
АБС. Обрыв датчика скорости "Левое Заднее Колесо, Датчик Скорости Входного Сигнала 0"
Дворник задний "Wiper rear motor speed sense circuit failure"
B1869 Lamp air bag warning indicator circuit open
B1898 Chime input #2 circuit short to ground
B1676 Battery pack voltage out of range
пс. все есть в гугле
На медведя я друзья
Выйду без испуга
Если с другом буду я
А медведь без друга
orackul
#2
 *pozor*
orackul
P1703 - это при самотестировании (Key On Engine Off (KOEO) Self-Test) вроде нужно было нажать ножник (или верхний стоп - не сориентируюсь без схемы). а ты забыл, или он не сработал. Там ниже возможные причины описаны (Possible Causes).
вот из стандартного переводчика - вроде все понятно:
  - Обрыв или короткое замыкание в (BPP) схемы
  - Обрыв или короткое замыкание в цепи стоп-сигнала
  - Повреждение PCM
  - Повреждение выключателя стоп-сигнала
  - Misadjusted выключателя стоп-сигнала
Диагностические Помощники: Проверьте, правильно ли функция stoplamps. Используя сканирующий прибор, проверьте BPP PID. Stoplamps и PID должны включать и выключать при активации педали тормоза.
P1780 аналогично, наверно эт ты при сэлфтесте забыл о/д врубить/отрубить.
У тебя в движении когда о/д кнопкой выключаешь, она срабатывает? Проверить можно при скорости больше 80, если сделаешь офф о/д, у тебя движком можно будет тормозить и обороты подпрыгнут.
B1453
Это стеклоочиститель/стеклоомыватель короткое замыкание на землю показывает в переключателе.
Он у тебя работает нормально?
B1869
Неисправна цепь индикатор лампы подушек - она вообще стоит? Либо, контакт окислился, либо вынули нехорошие люди после аварии/ремонта, либо сгорела - что оч большая редкость.
B1998
Со стороны переднего пассажира, разрыв цепи на боковые подушки безопасности. Связано, как ты понимаешь, с предыдущим пунктом. либо сработала, либо не подключили, после ремонтов.
B1676
Это ему напряжение на аккумуляторе не нравится (не попало в диапазон). Попробуй сбросить - может это старый аларм сохранился.
B1342
Не встречал такую ошибку. Попробуй схему на свой год глянуть, там поискать модуль DSM. Может на нем просто контакты по питанию окислились, поэтому он и ругается на аккумулятор и на gem.
Может кто что еще добавит
Осталось найти что это за модуль DSM
TransLab
Цитата: orackul от 03 февраля 2013, 09:40Осталось найти что это за модуль DSM
Driver seat module - модуль памяти водительского сиденья.
Цитата: orackul от 25 января 2013, 16:06Code: B1342
Внутренняя ошибка модуля. Требуется замена модуля (DSM).
