1FM Ford Motor Company, USA - Multipurpose Passenger Vehicle
D Hydraulic Class D:5,001-6,000 lbs Restraint Cat. 5 Hydraulic Class H: 9,001-10,000 Restraint Cat. 2
U34 EXPLORER XL 4 DR. WAGON - B - 4/W/D
X 4.0 litres SOHC OHC-MFI
T 1996
U Louisville: Louisville, Kentucky
Production Date 12/19/1995
AC, Heating, Cooling
AC MANUAL AIR CONDITIONER
Cooling Hose Lower F57A-8B273-F*
Cooling Hose Up F57A-8B274-F*
Radiator ID F57HN
Axle & Drive Line
Axle Front FWD D333D
Axle Limited Slip LIMITED SLIP REAR AXLE
Axle Ratio 3.73 FINAL DRIVE RATIO
Axle Rear RWD 613B
Case ID F57A-7A195-C*
Shaft Front ID F57A-4A376-A*
Shaft Rear ID F57W-4602-N*
Speed Drive Gear C0DD
Color & Trim
Color Interior Code 2
Color Trim F
Paint Code UA
Trim Color Description MED GRAPHITE
Tutone Color TR
Tutone Paint Description ROCKER TU-TONE PAINT
Trim
Bumper Front CHROME GRAPHITE XL/XLT
Bumper Rear PAINTED GRAPHITE EUROPE
Grille BRIGHT TITANIUM - XL/XLT/EDDIE BAUER
Mirror Out BLACK POWER EUROPEBRAZIL
Moulding Body 5 GRAPHITE
Moulding Low Body LOWER B/S MLDG
Stripe Misc D SILVER-GRAPHITE SPARKLE
Trim Pack XLT VERSION
Domestic Special Order
DSO Bumper Grill D
Emissions & Fuel
Charge Alternator JB
Engine Tag ID 6G948BA
Engine Type COLOGNE 4.0L OHV EFI NA V6 GAS
Fuel System AFT ID F67D-9K007-C*
Instrument & Lighting
Instrument Odometer KPH/MPH SPEEDOMETER
Instrument Cluster Id F67F-10849-E*
Options
Door Lock Option POWER EQUIPMENT GROUP
Sound Radio ELECTRONIC AM/FM STRO/CASSETTE
Speed Control Option SPEED CONTROL
Sun Roof POWER SLIDE SUN ROOF
Other
Vehicle Description EXPLORER 4-DOOR 4X4
Seating
Power Seat Passenger POWER 6-WAY DRIVER SEAT ADJUST
Power Seat Driver POWER 4-WAY PASS SEAT ADJUST
Specifications
Gross Vehicle Weight 05320
Spec Dist Code 9G
Steering
Steer Assembly F57C-3504-G*
Steer Shaft F57A-3E751-A*
Steer Tilt TILT STEERING WHEEL
Suspension
Suspension Spring Id Rear F57AFD
Suspension Spring Id Front F57A-5B326-B*
Transmission
Transmission ID 96GTEBA
Transmission Type 4 SPD AUTO EAO A4LD*E/4R44/55E
Wheel & Tire
Tire Size P255/70R-16 OWL A-T
Wheel (RPO) 112
Wheel Cover ID F57A-1A108-C*
Wheel Cover Road F57A-1015-G*
Wheel Cover Spare F37A-1015-C*
Wheel Cover 7.5 X 17" SPORT ALUM WHEELS
Wheel Cover 7X15" 8 HOLE DIRECTIONAL ALUM
Wiring
Wiring Entity F57B-14630-E* Code: RP
Wiring Entity F57D-14405-A Code: RN
Wiring Entity F67B-12A690-F Code: R1
Wiring Entity F67B-14305-A* Code: RL
Wiring Entity F67D-14401-A Code: RM
